transfer case
truck31
I have a 1999 Yukon 5.7. Can I disable the 4 wheel drive. I have a bad transfer.
Mechanic421
06 Denali XL
Statesville North Carolina
Be more specific. Do you want to remove the transfer case,front axle housing or just don’t engage four wheel drive? But if you get a two wheel drive transmission yes or buy a two wheel drive out put shaft and tail housing and have it installed in your transmission.
T
truck31
My transfer case is bad and I don’t want to dump a lot of money into it. Can the front driveshaft be removed and be ok?
I think @Tonyrodz removed the front driveshaft of his nbs to clearance his headers, no ill effects as far as i know.
Yup. Only thing, so far is throwing codes. You can only see them if you have the proper scan tool. Other then that, it doesn't trip the check engine light.
jmart157
