Tips and tricks for installing timing chain on
Tbruz
Windham NH
I'm deep into the timing chain job and I'm ready to start re-assembly.
I planned on installing crank gear first( heated up to 200 degrees F ) it slipped right on the crank snout.
Chain is fully oiled, timing marks on cam and crank aligned and chain is draped over the cam gear.
I cannot for the life of me get the cam gear back on......I walked away after 45 minutes of some very colorful sailor language......with no success, even went as far as pulling off the crank gear and trying to get both gears on simultaneously.........
any tricks or tips for tomorrow efforts are truly appreciated.
Thanks
Tbruz
wjburken
Eastern Iowa
Thanks
Tbruz
I’ve had good luck with putting the chain around the crank sprocket, put the chain on the cam sprocket and then line up the cam sprocket with the cam and put it into position.
Should go on just like Wade said otherwise you might have the wrong chain shouldn't be that tight
exp500
I've seen this before on a Vortec. Thought it had to do with the 2 choices of timing gears, but after investigating and verifying part number it came down to re-using old crank gear. That was on a customer supplied parts job so I didn't go any further investigating.
Cloyes always worked for me. Not even sure What MFR. customer provided.Probably Chineeseium.
T
Tbruz
Windham NH
I got the entire new timing set on this morning after about 25 minutes of fiddling with it. I ended up having to install both gears simultaneously and then tapping down the crank sprocket with a 36MM socket.
It is a Cloyes C-3017 set and is a 100% match to the set I removed.
Thanks for everyone's input.
Regards
Tbruz
Regards
Tbruz
Thank you for closing this issue with a post on your method for getting the two gears and chain on. Our collective knowledge base has been increased.
YETI the Yukon
