In in the process of replacing my transfer case in my 02 Tahoe (4l60e and np246). I believe I have suffered the dreaded pump rub causing me to loose fluid and wreck the case.
Is there anything else I should replace while I have it apart, other than u joints. Are there seals that should really be done on the output of the transmission or anything? Im getting a used case to put in, so should I get the new clip to fix the pump rub? Can I get it from a dealer?
