watuzi
- Joined
- Apr 28, 2015
- Posts
- 65
- Reaction score
- 25
Recently, my '05 4.8L Tahoe had an intermittent starting issue. Sometimes when I start the SUV, it would hesitate to start just for a split second but would start normally. I seemed like a weak battery that was starting to die. But the other day at work, when I the same problem occurred, someone noticed there was a spark under the SUV when I started it. I went home and checked under the starter. I didn't see anything wrong with the starter or the connections. I removed the starter heat shield and noticed one of the ears was burned. My guess is the heat shield was causing an arc with the starter terminal. I removed the heat shield and the problem has gone away. Problem solved.
Just sharing this with you all.
