(Solved)No turn signals...hazards work fine.
silky28
hey all,
So went out today and had no turn signals, not even a click from the flash module. The 4-way hazard light work perfectly.
So removed the flasher module and tested the turn signal wires...at the module. I got .110 colts on both.
Is this normal? I would expect the. Outage to be at least 6volts
Now that I think about it, it must be normal. The hazards work and they give basically the same voltage when on.
S
silky28
Those are already checked. The trucks Right turn signal side body marker and the left turn signal side body marker are both fine.
exp500
Maybe someone has the wiring diagram for this one. Hate to suggest combination switch when guessing.
Fless
Super Moderator
Elev 5,280
I can't tell for sure if you checked the turn signal fuses. EDIT: I think these fuse the side markers, too.
The fuse block access door is on the driver’s side edge of the instrument panel. Pull off the cover to access the fuse block. You've verified voltage at both sides of these fuses?
Fless
Super Moderator
Elev 5,280
Not sure if this will help, but take a look. From Haynes, FWIW. Not sure if you have SUV or pickup...
  • Exterior Electrical.pdf
S
silky28
Thanks all...turns out it was the hazard flasher module. Popped new one in and all was good.
exp500
Please EDIT your title and add "SOLVED". Helps people searching for solutions. Thanks.
bl74
