Sluggish turning over push to start?
jsams22
2015 SLT Yukon.
Whenever I am going to start my Yukon, I push the button and there is a good .5 sec delay, then the engine turns over and starts. My last service at the GM dealership reported a DTC B1517 code, 03 - voltage below threshold. I just got the battery replaced 3 months ago, so I got it swapped out for a brand new one. You can tell there is a huge draw of power and all the lights on the instrument cluster go dim. Its a very similar feel to when your battery is going dead.
With the battery being brand new, and the battery terminal connections being solid. Where should I go next? Check the connections to the starter? Could the start being going bad and requiring more draw to turn engage?
You may have already checked this, but is the battery ground cable to the block/chassis lug clean and tight at that endpoint?
J
jsams22
I have not looked yet. Trying to determine the best place to start.
sealandsky
Minneapolis, MN
2015 SLT Yukon.
There is a ground terminal on the rear of the left cylinder head - hard to get to. I'd put that on the list of things to check.
Brian12019
