slipping
Took in for bi-annual CA smog check. It failed due to the SES light not working properly. Turn key to on position, SES light comes on as intended. Start motor and light goes off, no codes. If you turn off then right back to on position, the SES light does not come back on. If you turn off and wait about 10 seconds to turn on then the SES light comes on as intended. For that little 10 second delay, because the light does not function if you turn off then right back on, it fails the function test. Emissions portions flies no problem. Anyone ever had this problem before? I have checked all fuses and replaced the bulb.
