Don't have to be on the brake ...
To shift to the 4LO position, the ignition must be in RUN
and the vehicle must be stopped or moving less than
3 mph (4.8 km/h) with the transmission in NEUTRAL (N).
The preferred method for shifting into 4LO is to have
your vehicle moving 1 to 2 mph (1.6 to 3.2 km/h).
Press and release the 4LO button. You must wait for
the 4LO indicator light to stop flashing and remain
illuminated before shifting your transmission in gear.
---------- Post added at 03:41 PM ---------- Previous post was at 03:40 PM ----------
Or To shift from 4LO to 4HI, AUTO 4WD or 2HI,
your vehicle must be stopped or moving less than
and the ignition in RUN. The preferred method for
shifting out of 4LO is to have your vehicle moving
1 to 2 mph (1.6 to 3.2 km/h). Press and release the 4HI,
AUTO 4WD or 2HI button. You must wait for the 4HI,
AUTO 4WD or 2HI indicator light to stop flashing
and remain illuminated before shifting your transmission
into gear.
---------- Post added at 03:44 PM ---------- Previous post was at 03:41 PM ----------
It did it again when I came home from Colorado. I had it in Auto 4WD and the lights all went out. Only seems to do it when it's cold and wet. I took the switches out and re-soldered the pins but that didn't seem to help. I went through a drive thru car wash and it started working again.
I'm thinking it is a harness / connector issue on the T-Case itself. I'm going to go put it up on ramps and check it out.
