Reverse wire?
98chubby
I'm trying to hook up a back up camera and can not find the reverse wire. Does anyone know where it is or has anyone installed one in their hoe? help me out if possible. Thanks guys
sparg93
Expedition Tahoe
NJ
If you splice into that backup wire, check how many AMPs your backup camera is going to pull and then check the current load on the OEM wire.
Those wires are really thin and have a long run to them...may want to consider running a relay to the battery to be on the safe side.
qukon 95
i tapped my reverse wire at the trans you will not find it
under the dash and it's a green wire.
98chubby
Is it working good? cause i am about to start on mine monday!!!! im so excited and i'm doing my double din install!!!!!
Leno1364
