rear diff
Gtir007
pulled my diff cover and saw this, a little puzzled how the diff got these marks, also what diff can i replace it with, can i replace the diff without messing with the pinion gears? i saw a diff from jegs someone posted
rqggsbFJVkfLD_PhxdrvP_vZ_c7sqt4uMDJj0NB4s3o=w874-h655-no
Sparky_69
New Mexico
Pinion nut must have came loose
---------- Post added at 11:56 AM ---------- Previous post was at 11:52 AM ----------
You may have to reset the gear tooth pattern, new crush sleeve and pinion bearing, but if nothing is broken, you should be fine with that gear set.
G
Gtir007
the pinion seal is leaking, i haven't heard any grinding noises- do the diff. have anything to do with the gear ratio?
GinoTahoe
