Rear axle options
Czykats44
Dis Member
Glenville, NY
Situation, 99 Yukon G80 (GT4) 89k rear axle housing is toast, corroded beyond worthwhile repair... I've already welded the shock mounts once each and the roll bar mounts are simply gone. Not a fan of continued welding on the tubes.
Any good reman companies that anyone has experience with?
As far as junk yard stuff... Is an equivalent G80/GT4 pickup rear a direct bolt in just without the sway bar mounts.
Suggestions?
3dirtwheels
BMP, come on you performance wizards help this guy out. If that sounds unselfish, I'll confess I'm looking for something for my 383 install as well!!
Bill 1960
Testing the Limits
A recycled axle from a southern vehicle should be available from companies like LKQ. Down here in FL clean recycled axle housings are everywhere.
East Coast Gear is not too far from you IIRC. They can build anything you want.
fishcop076
