Rattle near center channel speaker
jjobev
I have 2023 Denali Ultimate. I am noticing a sound coming from the center of the dash when I go over bumps. It sounds like the noise you would get if something is loose and bouncing in the cargo area…only from the dash. I already had to have the drivers door panel replaced for a rattle caused by too much space between the panel and the window. The dealer fixed that problem but said they couldn’t hear the dash issue when they test drove it. At the time I wanted the vehicle back to see if door issue was resolved and didn’t have time to deal with the dash. Will have the dealer check it out again but thought I would check here to see if anyone else has had similar experience. Thank you
Tahoe14
Central Fl
Next time ride with the service tech and point out the noise you are experiencing.
golavaman
