Oscar@Hidguy
- Joined
- Feb 24, 2011
- Posts
- 98
- Reaction score
- 0
Introducing R-Tech License Plate (Top Mount) Rear View Camera and 4.5" LCD Screen Bundle, Dont have a Aftermarket Double Din but want a rear view camera? Then this is the solution for you! Comes with one Rear View Camera along with a External 4.5" LCD Screen that you can mount anywhere you like! All this for a shocking price of $140 with FREE SHIPPING anywhere in the United States. Dont Forget to use your discount code for added savings.
*** Camera Info ***
- Easy to Install; comes with all required Mounting Hardware and Wiring. 6 Feet of Power Cable and 18 Feet of Video Cable Included.
- Adjustable camera angle and a High Resolution camera for improved clarity and True Color Reproduction.
- Waterproof housing for long lasting operation and an Anti-scratch coating.
- Excellent low light sensitivity and auto white balance and gain control; Built-in Infrared LED's for Low Light Conditions.
- Will work with basically any In-Dash, Flip-Out or External TV Monitor that has a Video Input Jack.
Specifications:
Model: R-Tech Top Mount - Black
Imager: 1/4 DSP Color CMOS
System: NTSC
Effective pixels: 628 x 586
Horizontal resolution: 420 TV lines
Viewing Angle: 135° / 170°
Minimum Illumination: 0.5 LUX @ F2.0
Video Output: RCA connector, 1.0V p-p
Current Consumption: 50mA, Max 300mA
Supply Voltage: DC 12V
Item comes complete with:
- (1) R-Tech Rear View Backup Camera
- (1) Set of Mounting Hardware
- (1) Power and Input Wiring Harness
*** Screen Info ***
- Easy to Install; comes with Mounting Bracket and Wiring.
- Adjustable Base hold for preferred angling.
- Will work with basically any RCA Output Electronic such as Backup Cameras, Game Systems, DVD Players and More.
Specifications:
Model: R-Tech Universal 4.5 Inch LCD Screen with Mount - Black
Resolution: 480(H) x RGB x 272(V)
System: PAL/NTSC (Automatic throw-over)
Channel Input: V1/V2 auto switching (V1 display first)
Video Input: RCA connector, 1.0V p-p
Current Consumption: ≤2W
- (1) R-Tech Universal 4.5 Inch LCD Screen with Mount - Black
- (1) Power and Input Wiring Harness (5 Feet of Power Cable Included, No Video Cable)
Dont need the bundle? Only need the camera? We sell that as well for only $80 Dollars!
*** Camera Info ***
Specifications:
System: NTSC
*** Screen Info ***
Specifications:
