Question about the 00-06 Tahoe/Yukon DJM drop arms
Alex33
Do you know how these arms get the drop? I'm trying to decide if it's worth the swap to add these to stock spindles and drop keys or do drop spindles and stock keys. Any help is appreciated.
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
drop spindles will only lower 2 inches.
arms indexes keys so in turn creates 3 inch drop about.
if you use drop spindles stock keys and djm arms you will get 5 inch drop
A
Alex33
Thanks, I currently have keys and spindles up front, but I'm curious to see if the spindle/arm combo will ride better than the spindle/key combo. Do you recommend making the switch?
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
whenever you use keys i never liked the ride. also with a arms you will have full turning radius back.
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
spindles do but not much on the belltechs (the original 16 inch ones did)
but keys at 2 inch level ride very harsh.
I put spinldes in my truck and lost 1/8 of a turn not much at all.
WA Sparky
Washington
Ok, thanks. Just doing some research...figuring out if i want a 2 or 3 in front drop for my Yukon.
Luggz
