Power steering pump
Kelsda
New Jersey
Looking for power steering pump for 96 Yukon vacuum boost any brand to stay away from just read a lot of bad reviews on cardone do I buy the whole thing,just pump what about delco new or rebuilt then there is duralast same options I dont mind spending money especially not to do it again anytime soon ny info would be appreciated
east302
Mississippi
I'd go with an AC Delco over a Cardone, and a Cardone over anything from Autozone Duralast.
I suspect that Duralast is just going to be made by whatever manufacturer submitted the lowest bid to Autozone. I couldn't see Cardone or any of the other made-in-China specials being that much different.
Careful with the Delco Advantage versus Professional line. The Advantage is probably closer in quality to some of the low-end parts store brands.
Kelsda
Kelsda
New Jersey
Thanks for your advice
TigerEyz3
Slow and Steady
TN
What East302 said...
When I replaced my steering pump, I replaced the steering gear as well. I don't know what your budget is, but I've been very pleased with my AGR components. I changed my components a bit so that I could eliminate the electronic steering assist (basically went with a 1997 setup, which required lines that had a slightly different bend than the 1999).
Kelsda
Kelsda
New Jersey
Thanks I’ll check ARG out
rick3645
