Park Sensor numbers? 1 to 4?
tengelman
Hi there,
My 2011 Yukon Denali says "service park assist" and the OBD says that the rear sensor no4 is bad.
Which one is number 4?
Regards
Dennis
tengelman
tengelman
1 is drivers side.
2....3....
4 is passenger side.
I asked a dealer.
Easy fix. fast change.
You can always check each sensor individually by standing to the side of the vehicle and reach over and cover each sensor one at a time with your hand and listen for the beep, if one does not beep then it is bad or not connected.
tengelman
tengelman
@whitehoe: sorry...misunderstood your question.
If found out which one is bad with an OBDII-Device.
It clearly says the number. I just didnt know what side number 4 is first...
@Doubeleive: i dont think so. the sensor that was broken on my yukon made the whole system shut down. so as long as there are not ALL 4 sensors working you wont hear any beep...
Attention: After replacing - the error message does not disappear until you put in reverse the first time.
Pepper1700
