No brakes.
Denalibro76
Afternoon all, I have an 03 Yukon Denali (Hydroboost) and last night I had to hit the brakes hard. When I got home the brake pedal went to the floor accompanied by the service brake system and service stability system messages. No fluid leaking. Any ideas where to start?
OR VietVet
Multnomah Falls
Military
Willamette Valley
If you unbolt the master cylinder from the booster, you can check to see if it is leaking/wet there, at back of master cylinder. If is, that is a sign of a leaking master cylinder. If you replace the master cylinder, make sure to have a qualified tech do it or check here for needed bleeding info. You also could have a line/hose/connection as a problem. You said "no fluid leaking". Where did you check? Just looked on the ground?
Denalibro76
Denalibro76
Yeah. Checked all 4 corners. Fluid level was good as well. The brake pedal is not like a limp noodle…still a tiny bit of pressure on the way down.
Off Road Pedia
