Newbie ??? ACC and IGN Wire @ Column
VinninTX
Greeting Yuk & Hoe Brothers/Sisters,
Can one of the present gurus point toward the below wires within the column wiring bundle? Doing some rewiring on a 2007 Yukon XL and implementing a series of kill switches (not a believer in alarms or that anyone pays any attention to them).
1- Switched (from key) 12vDC Accessory wire
2- Ignition/Starter wire from key to the stater solenoid
Thank you much...
V
VinninTX
Reviewing various posts and multiple wiring diagrams online (mostly associated with alarm installation(s)), it seems all fingers are pointing toward ACC wire in column as a Yellow or Brown wire, then there is a "run" circuit as a Pink wire, and finally there is a ignition signal circuit (destined for the starter solenoid through the BCM) as a Pink/BK wire within the column bundle.
Off Road Pedia
