New to the Yukon world and need suspension help
h22dx
So I just bought a 99 Yukon SLE with 156k on it. I was looking to level it but not really lift it that much. Right now the front end sits higher than the rear. The only real suspension systems I have seen are 6+ inches which I definitely dont want to do. I could go 2 or 3 inches tops. What are my options? Thanks in advance guys!!
lukc22
They make replcement leaf spring packs to get you back to factory ride height... You can probably get em off of amazon... You could add small 2 inch blocks under your current leafs if you want to go cheap, but its not the best route...
lukc22
You could also do an add a leaf... that is kind of a middle ground between cheap blocks and full replacement packs
H
h22dx
I will probably go with the aal but might splurge and get new packs.
