95escahoe
- Joined
- Aug 2, 2010
- Posts
- 5,155
- Reaction score
- 4,453
Yesterday I installed the TBI unit I modded if your truck doesn't run right might be an issue with your TBI unit, its a straight forward easy project, when I took mine off found cracked gaskets, broken o-rings, plugged up vacuum line port, had a shake at idle that's gone now its smooth as glass now, I knocked the horns off on the TBI unit smoothed the top out, rebuilt it, 1/4, pod spacer, flow matched and cleaned OEM GM injectors.
Sent from my HTC One X using Tapatalk 2
