Mini d2s retrofit
mcislak
Looking for some input from guys who have done retrofits with hids. Ordered new housings and the morimoto mini d2s 5.0 Apollo 3.0 shrouds and a 55 watt kit all from the retrofit source. Got everything installed just fine but when I fire the lights up my drivers side works but my passenger fails to ignite. Tried swapping bulbs ballast igniters different relays everything. Same results. I have my drl disabled. Am I missing something 35be8275b4ca5210aa5b14f137ea5e05.jpga5768f3a802563efbd9c076ab76416f4.jpg167ed3f50a3773e82761404f9ef2f8ec.jpgf4d60680b2fee1ac1560bfb0cc415e26.jpg
K2 Kaiju
The Depths
Bulb out? I remember a retrofit I did years ago and the wire were backwards and you had to put put plug upside down...
Sent from my SM-T580 using Tapatalk
mcislak
mcislak
Bulbs are good. I think I might of figured it out. I turned off the approach lighting through my DIC and all has been working since
91RS
GA
What headlamps did you buy? Do you have any more pictures? I'd like to see how you attach the projector to the stock reflector. I'm looking at the same kit from Retrofit source. Thanks.
HACK BLOCK
NYC
how were u able to get off the orange reflector? I was trying to take it off but felt like I was gonna break it
mcislak
mcislak
On the back side of the orange reflector there is three or so tabs that I cut off and it came right off.
mcislak
mcislak
I just amazon searched for Yukon headlights. I believe the brand was eagle eyes
HACK BLOCK
NYC
ok I didn't know if I should have cut it or not
Agjncndjxnnn
