- Joined
- Dec 8, 2016
- Posts
- 3,689
- Reaction score
- 4,378
At 83K miles mine is still good but if it goes out I would not even bother to fix it. I will open and close it manually just as law enforcement does.
Yep, use super lube or even WD-40. Spray the hinges, the cylinders, basically any part that moves. This alone will often fix a door that opens partway and then starts to close again.Try spraying your seal with silicone spray. Should keep it fairly loose.
