Got my 02 Tahoe in the shop right now, she's undergoing a transmission rebuild. I'm preparing her for a supercharger, cam, headers, and a couple other mods that will easily push her over 500hp next year. If you are like me, and have never had a transmission rebuilt, it can seriously hurt your head and hurt your wallet. My situation was I had a warranty on mine, so I took advantage of it. My transmission was doing what they call a subtle "flare". That is basically where the tranny is not quickly shifting to the next gear crisply. It will rev the engine ever so slightly higher, rev it back down a fraction, and then go into gear. It took 3 transmission shops to diagnose this problem because it was so faint. I'm a serious ass perfectionist to a fault....
Basically, as I understand it, transmission rebuilds are rated on the amount of hp and torque you gain from the aftermarket heavy-duty parts you install. The more robust parts, the higher the level. There are an enormous amount of things you can do to a transmission to upgrade it. Not being a mechanic of any sort, I was truly overwhelmed by it all.
I undertook the same strategy that I always do with things I know nothing about, I talked to A LOT OF PEOPLE! After calling a couple shops locally, hanging out at the local transmission wholesale parts warehouse, and chatting for about an hour with the master builder who is rebuilding it, I chose to do the following to support the power I'm going to add and minimize the hit on my pocketbook:
(RedEagle Master Rebuild Kit)
Alto RedEagle PowerPack 8 RedEagle clutches
7 Kolene full thickness steel plates and 1 thin backing plate
Red Eagle 2-4 Wide PowerBand with hardened anchors
Shift kit with boost valve
13 vane pump
unbreakable Pump Ring Set
3/4 4th apply super-servo
1/2 intermediate super-servo
Five Pinion Front Planet Gears
Five Pinion Rear Planet Gears
intermediate servo release check valve
performance 1-2 accumulator spring
high output pump slide spring
Longest intermediate servo pin
29 element Borg Warner forward input sprag
double reinforced Roadmaster torque converter
beast reaction shell
Servo Valve
gaskets
filter
This is by no means a comprehensive list of things you can do, it can go on and on...one thing I will add later this year is a tranny cooler. Any suggestions please send!
B O S S
13 vane pump
Servo Valve
gaskets
filter
B O S S
