I just got a 99 suburban 5.7 with 175k miles. Was told the truck had a coolant leak that couldn't be found. I looked it over and found the radiated cap Completly shot I replaced and found a leak on a block off nipple on the radiator. Simple fix but now the truck is running like crap ever since the cooling system is pressurized from the new rad cap. I tried blocking off the breather tube and PVC valve on the valve cover and checked for negative pressure on the dipstick and found none. Any ideas? Truck ran great before i messed with it
