Here is what I got when I did mine.
MS98000T Premium intake gasket set
ES72224 Intake Bolt set
VS50293R Valve cover gasket
(The MS9800 gasket set will include one valve cover gasket, but I got the VS50293R so I could do both valve covers. In my opinion, it also makes it easier to re-install the intake manifold without having to tilt it in.)
Also be wary of the manifold heater hose quick-disconnector. If the retention clip gets damaged during removal, replacement of the threaded assembly can sometimes present a problem. (The Manifold threads are know to sometimes strip when attempting to replace the whole quick-disconnector.)
The Fel-Pro gasket set has torque specifications that ship with the gasket, and if I remember properly, it is installed without sealant around the water jacket ports. (Some people might disagree with this though.) I did clean very carefully and used a solvent to make sure there were no traces of oil on the cylinder heads/block end sealing surfaces.
Mark your distributor very carefuly! (Rotor to body, Base to manifold, and a firewall reference.) Then take a few pictures of the markings. Don't use a black permanent marker like I did! (The pictures saved me after my greasy hands blurred the marks.) Use a yellow marking paint pen or something similar. Or scribe some lines.
I also waited overnight upon re-assembly for the silicone end sealing to cure before starting.
That's about all I can think of for now.
gl
