How to install E-Fans
JennaBear
Resident Ninja
Supporting Vendor
San Diego, CA
Rather than crossing lines, make sure you follow what Justin has discussed with you via email. You purchased the wrong harness, but we are having you do a work around.
In short, the PCM you are going to use, needs to be sent in to be set up for PIN 33.
TWITCH101
As stated before you have the wrong harness. Pin 33 doesn't work for you. Stop looking at pin 33 lol.
For the 03+ it measures a c pressure or some crap to activate the fans. We older trucks pick the signal from the a.c. compressor turning on hence the need for what should be a wire tap on your harness instead of a pin connection. So when my compressor turns on one fan activates on hhigh.
Like I said the 03+ trucks have better fan control but our setup does the job.
No idea if you can modify your harness or not.
The security relearn process is on here somewhere. A scan tool should be able to get rid of check engine light code that follows.
Thanks for the help....I'm still working with Blackbear at the moment. If they think I can get a better setup and not have to hassle with an additional harness then I might go that route but I'm just so confused at the moment. I understand what I need to do as far as I could take the easy way out and just get the correct harness and be done with it. But I think Blackbear has another idea for me.
Your last sentence is the one that confuses me the most.
There is already a pin in my #33 slot on my PCM. So how will I manage to fit another PIN into that slot?
If Justin reprograms my PCM for that slot(#33) as a fan control then what function do I lose?
What does the #33 pin control from the factory?
JennaBear
Resident Ninja
Supporting Vendor
San Diego, CA
Ignore my last post, as I don't want to confuse the situation. Don't worry though, Justin will get you all figured out.
TWITCH101
Will do. I hope we are all on the same page is my only real concern.
Could my yukon having autoride be a reason that pin #33 is currently in use?
JennaBear
Resident Ninja
Supporting Vendor
San Diego, CA
No, that PIN does not have any bearing for you. It all has to do with the programming. Justin can take care of it.
01HDtahoeNJN
Shredding Gnar Daily
North Jerz, NJ
Gonna buy the bb harness for my 2001 lt which one should I get the 2005 one w overdrive or the ls1 w/ overdrive!?
TWITCH101
I bought the 05 with the overdrive pulley. I Am currently waiting on my PCM to be programmed and mailed back to me. If you can wait a week I can let you know how mine works.
BB is re-working my PCM to accomodate the pin#33 so that I don't have to tap into another wire and now both fans will be controlled by pcm. I would say go the same route as me but I would suggest waiting and seeing how mine works out. Then make your decision.
beav626
Oklahoma City
Hey guys- I traded my 03 for an 09. So I have the E-Fans out of my 03 (06 Denali) and Nelson Harness that I am selling- If anyone is needing one or knows of someone send me a message.
Thanks
MRFULLPULL
