Hid
sparg93
Expedition Tahoe
NJ
Just went onto the site to order it and he wants $15 for the part and $15 to ship it!!!
Any recommendations on how to get this kit for $15 shipped per your previous post?
sparg93
Expedition Tahoe
NJ
Lax - thanks!!
I currently have the HID harness...I'm assuming I can use the 4-high harness with the HID harness?
laxman21
Lax - thanks!!
Yes you can as the 4 high kit splices(really clips in) into your factory wiring harness on the passenger side before you plug it into the HIDs
laxman21
Here is my set up
laxman21
Here is my set up
Ground wires all together with the bolt
Ran a 10G wire to the ground by the battery
Positive hook ups. HIDs to battery and 4 high to distribution block
gulleyman
TX.
Ok cool, ya I got the Raptors for my high's and low's. Does anyone know what type of diode you're supposed to put between the two relays for the high 4 upgrade with the HID's? Every write up I come across doesn't say and eventually becomes a sales pitch for someone's home-made kit:Wedgie:
99Yuk
Northern Ontario, Canada
It can be any type of diode as long as it can handle 10amps.
I pulled mine from a used broken pc atx power supply. Each one has 4 diodes in it that can be salvaged and reused. Just go to any pc repair place and ask for a free broken power supply. Tell them that you want the diodes. Most pc repair places will plenty of broken power supplies laying around and will be glad to offload one or two of them.
If that doesn't work then radio shack it will be, or mouser.
willb
