I have a obs 99 4 door chevy tahoe.
Problem: My heat only blows cold and heat control doesn't work, and the control for the location of where the air blows doesn't change and its stuck on defrost....
I thought maybe it was the blend door motor so I swapped out the one by gas peddle and it did not fix it. The other two are almost impossible to get to without removing dash. This issue occurred after I added subs and amp to my already installed aftermarket head unit.
Do you think because it is more then one thing maybe it is the climate controls that are bad? Has anybody every had all this happen at once?
Thanks
Thanks
