Headlights, 11" lift.
scorpio2868
This is my first post, so im mot sure if this is where im suppose to put it, but Can I get some headlight suggestions? 97 tahoe running 35's with 11" total, factory lights are not bright enough.
NathanJax
Vacation Nathan
Administrator
Jax, Fl
With that setup, you'll never get enough usable light. Headlights need to be lower to ground then what they will be.
Maybe @01Konvict could help out, but you definitely not some type of good projector
01Konvict
Boats n Hoes
Raleigh/SML
Need to get a set of euro clear headlights then retrofit some morimoto mini h1. Those are the smallest projectors on the market besides matchbox. Done right you will be able to light up a LOT!
01Konvict
Boats n Hoes
Raleigh/SML
Best to talk to the retrofit source and make sure you get the old version shields that don’t limit foreground for the minis. It helps in the lifted application so the road is lit up without the limiter.
Thekenstar
