Booyahzman
So I've been doing some troubleshooting with some wiring and installing projectors into my truck when I put a bad connection together and I believe blew the fuses for my low and high beams. However, I'm not sure exactly what I'm looking at or what I need to replace. Do I need to replace the HDLP-HI and HDLP-LOW relays? Is there a way to test to see if those are the actual parts that are bad?
Thanks in advance!
---------- Post added at 12:22 AM ---------- Previous post was at 12:01 AM ----------
Nevermind, I found the solution and problem; a 10A fuse was blown. Replacing it gets my headlights up and functional again!
Thanks in advance!
