the big blue bus
almost done making my own hd harness. the relays mount to the drivers batt tray on the inside. power wire is 10g split to both relays and fuses on each. 14 gauge wire to new headlight plugs and the grounds. no alteration of stock harness done too. sodlered in a diode between low and high trigger for 4 high mod instead of relay should get rid of flicker. measured 14.4 volts at batt and 13 volt at stock headlight plug, so loss of 1.4ish volts. when done ill measure again and see if it improves. have pictures of inprocess but need more wire for high beams and to pick up one more head light plug from junk yard and swap them to 14 guage
