Foglights and Mudflap Install
Tylus
South GA
Put some aftermarket foglights on, and OEM front/rear mudflaps. Had the mudflaps for almost 2yrs...just never got around to installing them.
Foglights: Only need a 7mm and 10mm socket for the foglights. Super easy to install. Picked them up in November for $120 off a Vendor on eBay. They come with bulbs and a short pigtail. Nice product.
  1. Remove wheel
  2. Remove bolts on front half of splash liner (7mm bolts)
  4. Remove 2 bolts (10mm) on bottom side, and pull push pin retainer out
  6. Tie splash liner back out of the way
  8. Remove 4 bolts (7mm), and remove the foglight blank
  10. 1 bolt is different of those 4. the inner most bolt is a shorter one that is used to anchor to plastic. the 3 remaining bolts are the same as those used to anchor the splash liner
  11. Here is a 1/2 way look. Reverse the process to install foglights. I will be doing the wiring later. Just wanted to get the hard part done. Took me about 1.5hrs all said
  13. Finished!
Mudflaps: Nice product. Fit the fenders nice, and extremely easy to install. Can be done with tire on, but I took advantage of the extra space.
  1. Remove 3 screws (T15 torx bit) and remove rock guard
  3. Clean the area using alcohol
  4. Slip mudflap into place and secure using 3 screws from original rock guard
  5. Drill 1/8" hole in the 4th hole using flap as a guide
  6. Install 4th screw into hole
  7. Peel liner off the double sided tape
  8. Done
Kpwweb
Great write up!
How do the factory tow hooks attach? (Pics of those?).
Kpwweb
Great write up!
Never mind. Google search found it (but forum search did not?).
Thanks for the nice writeup!
Tylus
Tylus
South GA
now you got me curious. gonna take a look when I'm wiring it up. it's a mandatory item for Guam/Hawaii. They can't ship/sell a car out here without tow hooks.
jem556
KY
Still waiting on a thread where someone actually wires these fog lights up and makes them functional...
whitlecj
Great work on the write up! Fingers crossed we get a similar write up on wiring them!
Tylus
Tylus
South GA
That's today's objective. Going to use a simple relay circuit for each one
Still haven't decided to use a 5 or 10 amp fuse though
Kpwweb
10A for the lights = 120W
What size wire are you using?
Angel87
I'm interested with how you wire it up as well. I thought about buying an aftermarket kit and just having them install directly to the battery but I'm open for other options. Looks good btw
93blkongreenpro
Relay them off of the drl. Simple. Clean. Effective
Sent from my SM-N910P using Tapatalk
justjacks07
