E-Brake adjustable?
Rexxrally
Edmonton AB Canada
My 2005 Yukon e-brake pedal goes all the way down when I press it. The e-brake does seem to work, because it holds it in place. But, I'm wondering if it's possible to adjust the e-brake up a little tighter, so the pedal doesn't go all the way down.
Thanks for your help.
JoeOmerta
Buffalo, NY
There's multiple adjusters on the vehicle, at the rotor/drum which should only be used to set the shoes/drag, along the body on the drivers side just outside the frame rail which is what i'd use to set pedal stiffness.
Jnice28
