Dropped that Hoe
OklaHemi
Well i set out to get started today around noon in order to hopefully have it put back together tomorrow, but everything went better than expected. I had the back done(minus sway bar links) in about 2 hours then spent the next couple of hours on the passenger side. I made the mistake of not inserting the top bolt for the wheel hub before putting the spindle in place:yuno: so i had to remove the upper arm bolt and fix it. drivers side took about an hour and a half to complete. once i had the wheels tightened and started the engine to level out the autoride i called it a day. about 6 hours total including lunch break and my 4 year old helping out. Anywho a couple of Pics
I will get better ones once i get it aligned and washed. I will be having the free travel mod done on monday at the lateset so it may be a sittin hoe for a couple of days.
LOWHOE775
Sparks,Nevada
Great job, looks good. What drop is that if I may ask? You planning on getting bigger rims?
O
OklaHemi
Thanks guys. It is the 2/3-4 drop for tahoes w/autoride from Tony. The wheels are 22 and i have thought about getting a set of 24 to play with, but these would remain my daily drivers.
O
OklaHemi
It rained off and on all day so I didn't wash it obviously. Here are two I snapped as we left the tire shop. I like it more and more every time I see it.
y
The paint will get fixed soon, as well as painted calipers. also swapping out the emblems, no more black
Anas1993
