Crown Suspension 2/3 Lowering Kit 15+ Tahoe/Suburban/Yukon
TheSuspensionSource
Supporting Vendor
Fresno, California
This kit includes a pair of 2" Front lowering springs. For the rear we have included 3" lowering springs which sit the truck perfectly level, also to help keep the ride as close to stock as possible we have also included a set of shock extender so that you can keep the same amoint of travel in your shocks and not have to replace them!
Our springs are wound from the highest quality spring material available. Hot wound springs are quenched and tempered. Both hot and cold wound springs are stress relieved in a continuous oven, shot peened to increase fatigue life, and set removed to guaranty the springs do not sag over time. We have state of the art load testing capabilities to ensure that the coil springs conform to the required load and rate specifications. All our coils are powder coated a gunmetal grey. Powder coating is a type of coating that is applied as a free-flowing, dry powder. The main difference between a conventional liquid paint and a powder coating is that the powder coating does not require a solvent to keep the binder and filler parts in a liquid suspension form. The coating is applied electrostatically and is then cured under heat to allow it to flow and form a "skin". The powder coat creates a hard finish that is tougher than conventional paint so that it does not wear rust or chip like conventional paint. Do not be fooled by other companies selling cheap china made parts that are painted and sag after time!
These are USA Made straight from the factory (Crown Suspension) no middle man!!
Lifetime Warranty
100% No Sag guarantee!
Included:
2" Front Lowering Springs
3" Rear Lowering Springs
Rear Shock Extenders
Vehicles:
2015+ Tahoe / Yukon / Suburban / Yukon XL
http://www.thesuspensionsource.com/crown-suspension-2-3-lowering-kit-15-tahoe-suburban-yukon/
rick3645
