skpyle
- Joined
- May 15, 2021
- Posts
- 395
- Reaction score
- 1,025
The last thing I needed to do before I could datalog for the Black Bear Performance tune was clean the MAF and the throttle body.
I was forewarned by the service manual that I would have to either perform the Throttle Idle Relearn procedure via a Tech 2, or let it relearn on its own. Luckily, my new Tech 2 showed up.
I carefully removed the MAF sensor from the air horn on the air filter box by removing the two T15 Torx head screws. Yeah...I know this is simplistic, but I was paying attention and didn't want to drop either screw. And I didn't want to screw up the MAF. The MAF came out no problem. Sensing wires and IAT resistor were in excellent condition, as was the sealing O-ring. Cleaning consisted of gently spraying both sensing wires with CRC aerosol MAF cleaner, then letting air air dry for awhile. Wipe off the O-ring, reinstall the MAF into the air horn, and call it done.
MAF mounting point in the air filter box air horn.
MAF, sensing side up.
Sensing wires and IAT resistor.
Only cleaning tool needed.
MAF back where it belongs.
