Chasing Misfire
badandyturbo
Florida
Hello friends. I have been hunting down a misfire in cylinder 2 for a bit now and I need some help.
Code is P0302. Misfire cylinder 2
I have swapped coilpacks.
I have swapped plug wires.
I have replaced the spark plug.
I have replaced the injector.
I have pulled the valve cover and checked rockers.
I have used 87 octane and E85.
Truck misfire is only noticeable at temp on idle. Cold start and driving it's fine.
Any other ideas?
Like Ron said compression test and I would check the injector harness voltage, check all 4 connectors on that side and see if they all read the same, it's not uncommon to have a bad harness.
OR VietVet
Multnomah Falls
Military
Willamette Valley
Yea, if you have a compression problem, that simple basic test could have saved you all this time chasing the problem and any parts you threw at it.
OR VietVet
Multnomah Falls
Military
Willamette Valley
If you do that compression test be ready to do a dry and wet test. If the compression is low, compared to other cylinders, then remove that tester and spit a little oil in that cylinder to see if the compression comes up. If it does, then rings are suspect, if not, then valves or head gasket is likely.
badandyturbo
badandyturbo
Florida
Ok so the compression is good. I have also used a noid light to check the injector. Its firing correctly. I am running out of options......
maybe hook up a scanner and get a live data feed going and try wiggling the injector wire harness and see if it correlates with that. If the hardware is good then it must be electrical.
Brian12019
