Ok, I got myself all ready for the infamous Intake Manifold Gasket change this weekend (99 Tahoe). Its been weeping a bit of antifreeze out the back of the manifold and a bit out the front for a while now, so its ready to be done. I'm also changing plugs/wires/cap/rotor/thermostat at the same time.
I picked up the Fel-Pro MS98000T gasket kit for the job. Now here is what I don't understand...there has been a ton of work re-designing these gaskets from GM and from Fel-Pro. Yet, the most common source of the leak is where the manifold joins to the flat part of the block, where the silicon bead is. So why all the development on the gaskets? I just don't get it.
BTW my truck only seems to leak after a short trip (IE it doesn't get fully warmed up). After a long trip I don't get any leaks appearing.
