gunslinger
2010 Escalade. Only able to get about a tenth of a gallon in at at time. Must wait for fill neck to drain about 10 seconds and go again.
I completely removed the large charcoal canister. The vent tube coming from the tank is completely free. I went to the gas station and had the same issue. Can I correctly assume the issue is not the canister or the evap solenoid? What more could it be?
I don’t know what obstruction could actually be in the fill neck. Im not sure if there is a secondary vent somewhere that could be clogged. I thought the vent going to the canister was the only one. Also the solenoid line appears to only be connected to the charcoal canister so I’m thinking it should be out of play as well.
Also the charcoal blew out everywhere when I blew air threw it. Hundreds of pellets. I read elsewhere this is not normal. Should I get a new canister anyway?
Help is appreciated, thank you.
