I've got the shop manual, and the procedure seems a bit of a pain. Yet, I've read posts by people who claim to know someone who did it in 30 minutes. The youtube videos I could find were either laughably stupid or unhelpful. If you have actually changed a half shaft yourself, what exactly did you have to disassemble to get the half shaft out? Is the lower shock bolt and the tie rod end enough--obviously all the half shaft bolts as well--or did you have to pull the ball joints too? I guess some of these rigs have scalloped flanges where the half shaft mates with the diff--I imagine that makes enough clearance to simplify things. I don't have the scalloped flanges, they're just round...
Also, does anyone know how many teeth are on the reluctor wheel for the ABS located inside the hub? I have the wheel on the half shaft and was considering getting a wheel hub from a later year. It seems like the wheel in the hub assembly would be a lot less prone to contamination. My exposed wheel on the half shaft has 55 teeth.
Thanks!
Thanks!
