Bose Speaker Noise - Right Rear Speaker - After Regulator Change
Dan Acosta
05 Tahoe, Pioneer HU w/ Stock everything else.
Bose Speaker Interference Noise - Right Rear Speaker - noise is speed effected
I know there are similar treads on this, but this happened after I changed window regulator.
Plug was a little loose, so I soldered wire direct to the speaker and made a direct connection and it still makes the noise.
Anybody have a similar issue after window regulator adjustment?
Also, had been working on the RSE console recently (LED conversion). Would/Could this effect or cause this?
Thanks Dan
DenaliBQ
check amp most likely the cause smack it a few times see if it goes away its under center console that was my cause
D
Dan Acosta
SO I bumped the center console at the RSE panel, and it went away. So, it may be either the RSE panel - which I was messing with or like you said the amp that is under there. I will have to further investigate. I hadn't thought of that.
pamelapanian
