Best manual with wiring diagram
doc73
I’m in need of a very detailed wiring diagram. What manual would have something for the following. I have 2 sets of wires(2each) at the front passenger side that have possibly been cut or disconnected. One set goes directly to the passenger side wheel. Neither set of wires have a connector. The Two wires lead directly to the passenger side wheel assembly have a grey wire with black stripe and possibly a yellow toned wire. The other wires that are dangling from the wiring harness also have a grey wire with black line but the second wire there is not near the same color as the second one leading to the passenger wheel. The stablitrak service warning indicator is on.
These are probably the wires for your front hubs which contain the ABS sensors.
You can sign up for the shop manual at AllDataDIY for detailed color coded wiring diagrams to help you make the repair.
SpyShops212
Do you have any codes? There is are two LT models. One is more loaded with the keyless start and electronic suspension. It could be for the struts/shocks. Post some picture please.
Trademark505
