A/C Not blowing
Tridaddy
My 04 Yukon XL has the automatic climate control. I can feel cold air at the vents, but the fan does not change speed, whether it is manually changed or on auto. Sitting still you can just feel the air at the vent , but at highway speed it is being forced out. The rear a/c is working fine, I think it is a separate system though. My battery died the night before the problem started, could this have caused a problem? I am the original owner and I have never had a problem with it.
phonedrn8
the fan resistor board is bad common problem it located on the fan unit under the dash about $49.00 and 1 hour changing it out
T
Tridaddy
Thanks for the info, is there a way to test it on the bench with a meter or o-scope?
Todd
T
Tridaddy
Does anyone have a service manual which they could share the procedure to test, remove, replace the A/C fan blower motor and the fan resistor board?
Thanks
sticks
Thanks
With all the time you'll spend testing the resistor, you could just change it. They are fairly cheap to replace and I think that it's gone bad by the symptoms you're giving.
T
Tridaddy
The problem is I do not know where the part resides, or what I have to do to get at it. Being my main mode of transportation, I would like to minimize me down time.
jfranco
You don't have a fan resistor board, none of the yukons with auto climate control do. I've got one apart right now. Instead you've got a blower control module, can't get it at advance auto/autozone and from the dealer its ~175 bones.
HAYN_HO
gulfport, ms FROM oahu, hi
sorry to "thread jack"
my 06 has a problem where the a/c blows hot&cold but #'s 5 went out and now # 4 just went out according to my wife..im on deployment right now and will be home really soon so i am going off of what she told me..
any ideas what the problem might be and is it easy to fix or should i save myself the hassle and send it to a shop to fix?
lady112210
