99' Tahoe 5.7 Vortec power upgrades
wcole35
Battle Ground, WA
hello everyone i am new to the forum and new to the vortec upgrade lifestyle. I have a 99 tahoe lt and about 3500 to spend. I have looked into a bunch of upgrades and bolt on kits but it seems that everything comes at the expense of the computer. and most of them pretty much wreck the entire cpu set up. (ie Edelbrock top end performance upgrade 2096) I really want to rebuild the engine but don't want to mess up the CPU system doing it. I see that people recommend intakes and exhausts. i also see that the #1 upgrade would be a tune. I don't really know how these work. should i buy the tune module or just pay for the tune? looking for a lot of help. thanks in advance.
The Vortec Newb!
atis
New Bern, NC
I am fairly new as well and just installed a crate motor. I added the Volant CAI when I did the motor swap. My next move is a BB tune.
97yukon
baton rouge
i ran a 14.9 with the upgrades listed in my sig. i will be installing a lt4 hot cam kit pretty soon and probably the 1 inch intake spacer untill i can afford a ram jet intake. with 3500 hundred you can make some big numbers. just have to talk to the right guy. but if your trying to make big hps, a tunes not going to get you there.
TigerEyz3
Slow and Steady
TN
If you've got a 99 Tahoe, you don't have TBI - you've got a Vortec (dry intake vs. tbi's wet intake). I wouldn't go backward in technology. Power and efficiency can both be gained with the Vortec compared to the TBI/carb setup.
W
wcole35
Battle Ground, WA
Thanks for the knowledge! I am going to STROKE this hoe! I am finding it increasingly hard to find top end stuff with this. I am going to use the eagle 383 kit with e-tec 170 heads, stock manifold and spyder. My engine guy said that he will massage the 170's as well. I am going to add cai and new 3" headers and exhaust. I will be getting it tuned locally as i have found a Chevy guru. Thanks to all for your help. This project will begin the first of February. i will post updates and pics when it begins.
atis
New Bern, NC
I would upgrade the spider to the new design. When I replaced my motor I pulled the stock spider, ever single fuel tube was cracked and caked at the tips where it enters the cylinders. I used fuel injector cleaner every 2 months and I sea foamed her 8 months ago...and still caked and crappy!!
TahoeJim
SE Ohio
When was the new design introduced? Where is it available to purchase now, GM or the aftermarket?
atis
New Bern, NC
I picked mine up from amazon.com . They moved the injectors to the ends. Amazon has it at the lowest price...around $250.
Smokin Denali
