99-06 Driver's side power window motor, $30 shipped
ScottyBoy
Shreveport, La
I have a used OEM power window motor in perfect working condition. Will fit the drivers side front or rear of any 99-06 truck,(or 07 classic) and will also fit a 00-06 SUV (Tahoe, Burban, Yukon, Escalade, Avalanche).
This is the motor only, not the entire regulator assembly. If your regulator cables are jacked up, you need to replace the whole assembly. But if only your motor is bad, this will get you going.
AEHaas
