Marbor
Morning all
I'm kind of in a bind here with trying to ground my 5 ch amp for better sound.
I've tried the seat bolts, rear net carage bolts and other grounding areas in the rear. None seem to work properly I get a faint light on my amp, but when I move it around it will light up quickly and off again.
I've grinded down the areas as well for better contact and nothing. When I run a line to the battery and engine area it works fine. What can be my issue? I did the same set up in my yukon xl and grounded to the seat bolts and worked properly. Anything different here?
