5.3 vs. LS1 what is the difference??
JKmotorsports
Austin, TX
If I'm not mistaken...the L33 block is aluminum? I could could be pulling that outa my ass though :shrug:
Edit: Yes it is:
L33
The L33 was an aluminum block version of the LM7, and was referred to as the Vortec 5300 ** in marketing materials. Power increased by 15 hp (11 kW), to 310 hp (230 kW), over the LM7, and torque was unchanged. It was only available on extended cab 4WD pickup trucks.
L33 applications:
* 2005-2007 Chevrolet Silverado 1500 4WD
* 2005-2007 GMC Sierra 1500 4WD
:pepper:
Here's some good info on motors:
http://en.wikipedia.org/wiki/GM_Vortec_engine#L33
Yes, the L33 is the aluminum version of the LM7, and the LS1 is basically an aluminum LM7 with a larger bore.
WickedGoat
Lebanon, MO
Just wondering what the difference is between the 5.3 in my 02 Tahoe and the LS1 in my brother in laws Trans AM. Just trying to learn more about these engines. Is there a good resource online where I can study up on these motors??
Rich
http://www.amazon.com/How-Build-High-Performance-Chevy-V-8s/dp/1884089844
I have this one and it is very informative. You should be able to get it at Barnes & Noble or any other good book store. It discusses all of the LS motors in depth from stock build to performance parts and dyno tuning.
LS1's are aluminum blocks and have specific heads and cams on them to give them the higher horsepower ratings. The LS1 in my '04 GTO has the LS6 aluminum block, LS6 intake, but LS1 heads and cam to give it 350HP and 365 TQ. A true LS6 has the LS6 heads and cam from the 02-04 C5 Z06 Corvette, which were rated at 405Hp. It goes on and on........
R
rms25thta
NC
Thanks, I will be getting one of these to get better knowledge of these motors.
tybardy
everyone needs a Hoe
Gilbert Arizona
do the LS1 heads fit on the LM7? and for that matter, can you swap over the top end parts... i.e. cam, intake, etc
Max
Mile High
Denver
most everything is interchangeable, lots of people putting L92 heads on their lq4/lq9/etc.
HMFDZ28
Hunt Sta, NY
Iron vs Aluminum.... Heads flow simmilar numbers but 5.3 heads have a smaller chamber CC... Same cam... different intakes... different exhaust manifolds.... different acc. pully offsets... want me to keep goin lol. In general you can interchange all of the valvetrain/heads/most rotating assembly components.
brandonkeefe
