2018 Yukon Denali Seat Memory
rinconmike
Hi. I just picked up a 2018 Yukon Denali with Ultimate Package to replace my 2014 Toyota Sequoia. Still learning all about it.
I have programmed the driver seat memory for button 1. Per the manual, if the car is running and in park, I can press and release the "1" button and it should move to the correct position. Also per the manual, if the car is off or not in park, I have to hold the 1 button until the seat movement is done.
Issue is with the car in park and running, press and release of the button does nothing. I have to press and hold until the movement is done. Is this normal?
Also, separate from the seat memory, the four loose clips were in the cargo space in the rear. Anyone know what they are for?
thanks,
Mike
R
rinconmike
The manual I was referencing is the quick start one. The detailed manual states you need to hold the button.
Bruizza
I was having an issue with this on my 17. Had to hold set until it beeped then pressed and held 1 until it beeped. All with the vehicle on and in park. ******* PITA compared to how it used to work.
JVega
