Hi everyone,
I'm facing a perplexing issue with my vehicle's transmission and would appreciate any insights or advice.
Background:
Thanks in advance!
Background:
- Had transmission filters replaced with Valvoline fluid at a local shop.
- Experienced delayed engagement leading to tire spins. The shop suggested the fluid level might be low and added more, which resolved the issue temporarily.
- Later, at a GM dealer, the transmission was flushed three times and filters were changed again due to concerns about the fluid type which I learned was critical.
- On hilly terrain, experienced a loss of transmission engagement and a flashing CEL. After restarting, the transmission seemed stuck in low gear but we managed to move to safety.
- A similar issue occurred about a year later in hilly areas, with the transmission feeling like it might disengage but not like the previous experience a year prior.
- These issues don't appear on flat terrain.
- I suspect the transmission fluid level is critical, and the vehicle might be sensitive to even slight variations in this level which is supported by bits I read in other posts about getting the level correct.
- Adding Fluid on a Slope: If I park the vehicle on ramps adding angle to add more transmission fluid, would that help? Could this cause issues if the fluid is slightly overfilled?
- Using Lubegard Additive: I came across Lubegard Platinum ATF Protectant, which claims to address shuddering issues. Is it advisable to add this to potentially slightly increase the fluid level? We do experience a harsh 1-2 shift, which was present before all the above started and the info on the Lubegard says their additive helps a bit.
Thanks in advance!
