camperhead
Ive got a 2015 Suburban That will not crank. Now. It has a brand new battery with 12.8 V. all the gauges come on and do a sweep, windows will go up and down, locks, unlocks, rear gate goes up and down. Security light on dash flashes when you lock doors and shut them. goes off when you unlock and open. I even when so far to take the yellow wire off the start and have someone turn the key to start, No voltage present when in crank. I've got a snap on scanner on it and it shows no security codes but it does have Codes P0615 Starter relay control circuit and P0617 Starter Relay control circuit high voltage.
BAck story to this vehichle. I bought it wrecked in RH front and both doors. Vehicle is reassembled and all doors plugged back in, Airbag module has been reset and everything. I should also note I drove it in the shop, this is happened since I've fixed it. I need to get it running so I can get it in our spray booth. Any Ideas??????????
